Rewrite matlab code for hardware
asai9493
Newbie
Newbie level 1
I am working on implementation of PLL (phase locked loop).
The implementation in MATLAB is done. It should be simulated in a similar way in hardware. Honestly, I don’t understand what a simulation in hardware means. Does anyone explain it to me?
I have read the software engineers use FPGA for software development. I am familiar with FPGA a lit a bit, like how to describe board in Xilinx, or switch a led on/off…such simple stuff.
Does a simulation in hardware mean to rewrite it for FPGA?
Please, could you give me some example how such code looks like
Matlab is a mathematics program. You built your PLL in "math", and it works, as you report.
Yes, you will need to build your PLL in "some device", that is, re-write for the device you want to use.
It would be best to do this for whatever real hardware device you want to use when you actully build your machine.
I don't think simulation in hardware in this context means to rewrite it for FPGA, that would be an implementation.
If you are creating an analog PLL then you would simulate it for hardware using something like SPICE or perhaps Verilog-A.
If you are creating a digital PLL then you would write VHDL/Verilog and simulate the digital design in Modelsim, VCS, etc
