TCL scripting problem
dark_lord14
Newbie level 1
hi all,
i want your help regarding this problem of mine...i am quite new to this tcl scripting....
if suppose i have an instance name a/b/c and a related netlist, how can i write a tcl script which will take an instance ( say c ) and will return the module name under which it is defined ...?
for eg : say this regexp feature will take the instance i_pscore and save it in a variable 'target'.
but please give me an example script which will return the module name for $target ( which is 'pscore' ) from the netlist....
thanx a ton...! :) !!
yx.yang
Full Member level 4
ZhuHai, GuangDong, China
1: If you familiar with Perl, it can do it throug trace the RTL code files.
2: If you have DC or PT, you can do it by using some DC/PT command to trace this, DC/PT call them attributes. For example: get_attribute -of_object [get_cells a/b/c] "ref_name".
Thanks.
rca
Advanced Member level 5
Marin
Your problem is more to know the Primetime command than the TCL.
get_lib_cells -of_objects $e
