TC74 interfacing problem with PIC18
ALIARIF93
Junior Member level 1
please help me out
I'm interfacing TC74 with PIC18f4520 using I2C.But I'm unable to get temperature reading form TC74.
Can anyone check my error..
Thnx:-?
View attachment TC74 TESTING.rar
Hello jayanth.devarayanadurga
Im not using i2c.h header file..
I've made my functions BY consulting datasheet..
So my master side funtions are working(If i'm right)
TC74 is not sending data to PIC MCU
My read a byte function is below:
Code C - [expand]
8
9
10
11
void I2C_DATA_READ()
 SSPCON1bits.SSPOV=0;
I2C_IDLE();
SSPCON2bits.RCEN = 1;   ///ENABLE RECIEVE MODE
while(!SSPSTATbits.BF);  //while recieve not complete
 //SSPCON2bits.RCEN = 0;   ///DISABLE RECIEVE MODE
 PORTB  =TEMP_READING;;
How do you know that TC74 is not sending data? How are you seeing the output? Are you displaying it on led or lcd?
What is the address you are using for TC74? Is it 0x9A?
Kindly Check my .C code file
  • TC74_main.txt
ALIARIF93 : just found out that you are doing the same project as me. but i cant get my project to work as well...
is this the board you are using ?
how to do that? im not very good at programming
Just take the i2c code and see if any statement has to written according to C18. I think most or all of the i2c code doesn't need any changes. you just have to take the code of i2c_wait(), i2c_Read(), i2c_write(), etc...
The address of TC74 is 0x9A
jayanth.devarayanadurga: I've written new code..But it also not working.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
#include<p18f4520.h>
#pragma config LVP = OFF
#pragma config OSC = HS
#include<i2c.h>
#include<delays.h>
void main()
while(1){
unsigned char  LastTemp;
DDRCbits.RC3 = 1;                 //Configure SCL
                                    //as Input
  DDRCbits.RC4 = 1;                 //Configure SDA
                                    //as Input
  SSPSTAT = 0x80;                   //Disable SMBus &
                                    //Slew Rate Control
  SSPCON1 = 0x28;                   //Enable MSSP Master
  SSPADD = 119;                    //Fosc = 48MHs HS+PLL
                                    //for 100kHz
 // SSPCON2 = 0x00;                   //Clear MSSP Conrol Bits
  IdleI2C();                      // ensure module is idle
  StartI2C();                     // initiate START condition
  while ( SSPCON2bits.SEN );      // wait until start condition is over
 Delay10TCYx(10);
  WriteI2C( 0b10011011 );         // write Address
  WriteI2C( 0 );                  // Select Temperature Register
  RestartI2C();                   // generate I2C bus restart condition
  while ( SSPCON2bits.RSEN );     // wait until re-start condition is over
  WriteI2C( 0b10011011);          // WRITE Address
  ReadI2C();                      // read in the temp
  NotAckI2C();                    // send not ACK condition
  while ( SSPCON2bits.ACKEN );    // wait until ACK sequence is over
  StopI2C();                      // send STOP condition
  while ( SSPCON2bits.PEN );      // wait until stop condition is over
  LastTemp = SSPBUF;              // LastTemp is a Global unsigned char
You said that you are not using library functions then why have you included i2c.h?
And where did you get DDRx in PIC? DDRx are registers of AVR microcontrollers.
//as Input
This code is working. I put an led on RB0 and tried to check if(LastTemp != 0) then RB0 = 1 and led is lighting. So, LastTemp holds some value. You have to print the value of LastTemp on lcd and see what value it holds.
#include<i2c.h>
#include<delays.h>
void main()
	unsigned int LastTemp = 0;
	TRISB = 0x00;
	PORTB = 0x00;
	//Slew Rate Control
	//for 100kHz
	while(1){
		Delay10TCYx(10);
		WriteI2C( 0b10011010 ); // write Address
		if(LastTemp != 0) {
			PORTBbits.RB0 = 1;
See the attached image. I have assigned the decimal value of TC74 reading to PORTD.
For temperature 27 degree C it is displaying 11011 which is equal to 0x1B and d27 which is right.
So, It is working.
#include<i2c.h>
#include<delays.h>
void main()
	TRISB = 0x00;
	PORTB = 0x00;
	TRISD = 0x00;
	PORTD = 0x00;
	//Slew Rate Control
	//for 100kHz
	while(1){
		Delay10TCYx(10);
		if(LastTemp != 0) {
			PORTBbits.RB0 = 1;
			PORTD = LastTemp;
  • aliarif i2c.rar
jayanth.devarayanadurga : I was not using the right value for SSPADD...By setting Crystal frequency My code works..Thanks for help:|
:jayanth , how to trigger TC74 to display the temperature to LCD?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
        Delay10TCYx(10);
        if(LastTemp != 0) {
            PORTBbits.RB0 = 1;
            PORTD = LastTemp;
this one ?
//for 100kHz
what does this mean?
Fosc is the crystal frequency of the circuit..?
Fosc is the oscillator frequency, not the crystal frequency.
The 48MHz is achieved through the use of a Phase Lock Loop (PLL) which essentially multiplies the crystal frequency by a set rate.
BigDog
