[SOLVED] TC72 interfacing with PIC18F452
syeda amna
Full Member level 4
Full Member level 4
Pakistan
I m trying to interface TC72 temperature sensor with PIC. I m using CCS compiler. The problem is SCK and SDO pins are in idle state.
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#fuses XT             //for crystal
#use delay (clock=4000000)
#include <flex_for_test_lcd.c>  //LCD driver
void main()
      int i;
      int value;
      output_low(PIN_E2);
      lcd_init();
//SPI//
setup_spi(SPI_SLAVE | SPI_H_TO_L);
output_bit( PIN_C0, 1);   //Chip Enable
 printf(lcd_putc, "%u" i);
spi_write(0x02); //For normal mode
spi_write(0x80); //Control Register Addr
i=spi_read(0x02);  //Reading value from MSB
I don't believe that the processor should be setup as a SPI slave. But it explains pretty well why you don't see any bus activity. I would try master mode.
FvM TC72 operates as a slave. I configured processor as a master. plzz help me.
Not in the code shown in post #1.
The setup is wrong in two regards: Setting slave mode and SPI mode 2. TC72 however expects mode 1 or 3. This setup should work:
setup_spi(SPI_MASTER);
