Tapered CPW: How to simulate
asmodeus
Newbie level 6
Bristol
Hello guys. I need as soon as possible some help on how to simulate at ADS a tapered CPW line. I found the option of tapered microstrip line but not for CPW. Any idea? Please its so importan for my project and I have stuck :(
Manjunatha_hv
Advanced Member level 3
INDIA
Hello,
You should be aple to see CPW TAPER model in ADS...
Some thing similar to the AWR Microwave Office (MWO) CPW Taper element as show in the attached picture...
If not use MWO which even provides the layout for your CPW structure...
---manju---
    asmodeus
asmodeus
Newbie level 6
Bristol
Yes this is exactly what I want but I cant find it at ADS.. I ll try to find soon AWR then
asmodeus
Newbie level 6
Bristol
Thank you very much for your reply. I attached you my project to give a look.It is AWR format. I checked the tutorial and i did it according to this. The problem is with the specifications that i have for my CPW (that i calculated from linecalc of ADS) the smith chart seems wrong. Need to increase s1 or s2 in order to see something on smith chart. Any idea?
