systemverilog testbench and vhdl
sandeepmasade
Newbie level 3
INDIA
1553 source code
Can any one suggest me where i can get the 1553 BC,RT source code in Verilog?
Re: 1553 source code
thanks goshka,
i need 1553 source code not only encoder decoder code
1553 mil-std-1553 military standard ?
yes... it has to compatible with 1553-mil-std..
Hi, is your goal to implement the signaling protocol of mil-1553 or to control an IC which acts like a RT and care of protocol(mil 1553)...
If you mind to use an IC for your purpose, I can suggest you something and help you for source codes...
Ilgaz
Hi Ilgaz,
No Iam looking for standard 1553B protocol source code in verilog.
if not then i have to implement.
I'm looking for HDL code for mil-std-1553 RT. AHDL, VHDL or Verilog. May be schematic sourses or thmsng what looks like it) Ilgaz, could you post some info, or send t PM, plz.
Use Holt HI6110 IC.. Read datasheet, it may help you...
You don't need to implement the signalling protocol in VHDL or Verilog...
Can any one suggest me where i can get the 1553 BC,RT source code in VHDL ??
Its hard ware design and implementation in FPGA
