install systemc linux
I am suggesting an alternative. But don't know whether it works. If it makes some wrong installation, nothing a big deal. Your systemC installation will be with some errors. Just uninstall as said in the INSTALL file.
The script works like this.
At a particular point it says 'uname -m'. if it is a 32 bit machine the output will be i686, if its a 64 bit machine it would be x86_64. The error is because of this x86_64.
Try doing "alias i686 'x86_64' " and then continue installation. It might work.
While installing your linux, did you used 32 bit Linux or you installed with 64 bit Linux ?
I'l try to find if there is any other possiblity to install systemc in 64bit machine.
