system generator vs. simulink HDL coder
salma ali bakr
Advanced Member level 3
simulink hdl coder download
what's the difference between system generator and simulink HDL coder...?
why should i use one and not the other?
do i see HDL code as an output of both or just .bit files ready for download on FPGA?
thanks in advance,
salma
nxtech
Full Member level 5
NO HIDDEN LINKS
system generator vs. simulink hdl coder
System generator generates generates parameterizable cores while Simulink HDL Coder generates synthesizable Verilog and VHDL code.
E
salma ali bakr
simulink hdl coder system generator
thanks a lot
but what does parameterizable core mean..? are you referring to the leverage of core generator to generate optimized blocks...?
so, there's no HDL generated from sysgen, it's only either a netlist or a bit file, right?
khouly
Advanced Member level 5
EGYPT
simulink hdl coder - download
system generator is a xilinx product , which is optimized to use xilinx FPGAs , but HDL coder generates verilog and VHDL codes generally without the dependencies on the certain FPGA technology
another thing u can use the output of the HDL coder in ASIC technology
khouly
salma ali bakr
aha, thanks mohamed...
so if my design is going to be implemented on FPGA then i should just use system generator...but i won't get an HDL file, it would be either the netlist or the bit file....but by HDL coder, synthesizable code is generated which can then be altered in any way i want, synthesized and implemented on FPGA or ASIC...
khouly
EGYPT
not any FPGA , only xilinx FPGA
the HDL coder , will generate HDL code , then u can synthize it for any FPGA or ASIC
Khouly
