If you set in DC variable timing_enable_multiple_clocks_per_reg to true, the tool will time the registers with both clocks. So, it will save runtime - you have timing for both clocks in on session (do not need to switch set_case_analysis). But, you may have timing from one clock to the other - call them asynchronous or set false path between them. It's up to you.
