Mirzaaur
Member level 2
hi all i am using this function to convetr integer to bitvector and Synplify gives error
pack.vhd(25): type bit needs a syn_enum_encoding attribute of "sequential" @E:"c:\synthesis\one\pack.vhd":25:22:25:29
code is here:- please have a look
PACKAGE convert is
function int_to_bv(int : in integer) return bit_vector;
END convert;
PACKAGE BODY convert is
function int_to_bv(int : in integer) return bit_vector is
variable temp : integer;
variable result : bit_vector(0 to 8-1);
begin
if int < 0 then
temp := -(int+1);
else
temp := int;
end if;
for index in result'reverse_range loop
result(index) := bit'val(temp rem 2);
temp := temp / 2;
end loop;
if int < 0 then
result := not result;
result(result'left) := '1';
end if;
return result;
end int_to_bv;
end convert;
best regards,
mirza
PACKAGE convert is
END convert;
begin
if int < 0 then
temp := -(int+1);
else
temp := int;
end if;
temp := temp / 2;
end loop;
if int < 0 then
end if;
return result;
end int_to_bv;
end convert;
best regards,
mirza
