farnaz_j
Newbie level 1
Hi
I'm coding a hexa port RAM using an IP Core generated module "dual port RAM". when I click the implement top module the synth process fails giving the error "ERROR:Xst:827 - "/myram/my_ram.vhd" line 137: Signal addrb_inp cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release."
It points to the line showing "process (CLK)".
my code is here:
I've read the code over and over but I don't figure out what is wrong with it. can anybody plz help me?
my code is here:
architecture Behavioral of my_ram is
--INST_TAG
component blk_mem_gen_v6_1
PORT (
clka : IN STD_LOGIC;
ena : IN STD_LOGIC;
wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
addra : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
dina : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
douta : OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
clkb : IN STD_LOGIC;
enb : IN STD_LOGIC;
web : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
addrb : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
dinb : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
doutb : OUT STD_LOGIC_VECTOR(15 DOWNTO 0)
-- INST_TAG_END ------ End INSTANTIATION Template ------------
end component;
signal a_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal b_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal c_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal d_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal e_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal f_out_reg: STD_LOGIC_VECTOR (15 DOWNTO 0);
signal ena_inp : STD_LOGIC;
signal enb_inp : STD_LOGIC;
signal wea_inp : STD_LOGIC_VECTOR(0 DOWNTO 0);
signal web_inp : STD_LOGIC_VECTOR(0 DOWNTO 0);
signal addrb_inp : STD_LOGIC_VECTOR(3 DOWNTO 0);
signal dinb_inp : STD_LOGIC_VECTOR(15 DOWNTO 0);
signal doutb_inp : STD_LOGIC_VECTOR(15 DOWNTO 0);
signal addra_inp : STD_LOGIC_VECTOR(3 DOWNTO 0);
signal dina_inp : STD_LOGIC_VECTOR(15 DOWNTO 0);
signal douta_inp : STD_LOGIC_VECTOR(15 DOWNTO 0);
shared variable count : integer := 0;
signal count_holder : integer := 0;
begin
inner_ram: blk_mem_gen_v6_1
port map(
clka => CLKM,
ena => ena_inp,
wea => wea_inp,
addra => addra_inp,
dina => dina_inp,
douta => douta_inp,
clkb => CLKM,
enb => enb_inp,
web => web_inp,
addrb => addrb_inp,
dinb => dinb_inp,
doutb => doutb_inp
process (CLK)
begin
count := count_holder;
if (count = 0 ) then
if (CLK'event and CLK ='1') then
if (ENA = '1') then
ena_inp <= '1';
if (WEA = '1') then
addra_inp <= ADDRA;
wea_inp <= conv_std_logic_vector(1, 1);
dina_inp <= DIA;
end if;
a_out_reg <= douta_inp;
end if;
elsif (CLK'event and CLK = '0') then
if (ENB = '1') then
enb_inp <= '1';
if (WEB = '1') then
addrb_inp <= ADDRB;
web_inp <= conv_std_logic_vector(1, 1);
dinb_inp <= DIB;
end if;
b_out_reg <= doutb_inp;
end if;
end if;
count := count + 1;
elsif (count = 1) then
if (ENC = '1') then
ena_inp <= '1';
if (WEC = '1') then
addra_inp <= ADDRC;
dina_inp <= DIC;
end if;
c_out_reg <= douta_inp;
end if;
if (EN_D = '1') then
enb_inp <= '1';
if (WED = '1') then
addrb_inp <= ADDRD;
dinb_inp <= DID;
end if;
d_out_reg <= doutb_inp;
end if;
end if;
count := count + 1;
elsif (count = 2) then
if (ENE = '1') then
ena_inp <= '1';
if (WEE = '1') then
addra_inp <= ADDRE;
dina_inp <= DIE;
end if;
e_out_reg <= douta_inp;
end if;
if (ENF = '1') then
enb_inp <= '1';
if (WEF = '1') then
addrb_inp <= ADDRF;
dinb_inp <= DIF;
end if;
f_out_reg <= doutb_inp;
end if;
end if;
count := count + 1;
elsif ( count = 3) then
count := 0;
end if;
count_holder <= count;
DOA <= a_out_reg;
DOB <= b_out_reg;
DOC <= c_out_reg;
DOD <= d_out_reg;
DOE <= e_out_reg;
DOF <= f_out_reg;
wea_inp <= conv_std_logic_vector(0, 1);
web_inp <= conv_std_logic_vector(0, 1);
ena_inp <= '0';
enb_inp <= '0';
end process;
end Behavioral;
