syntax error near process
parallax18
Newbie
Good evening,
I need your help for one technical problem. I can't solve an error in my VHDL soft project because an error appears
at the line "end process;" which tells me " syntax error near process".
Thank you very much for your help!
Next time please upload code and error messages as text instead of big filesize pictures. Use code tags.
Text also enables text search.
Good evening Klaus,
I transmit you my vhd sources. Thanks for your help!
  • projectaff.txt
Review VHDL textbook about correct case statement syntax. Each case needs a matching end case.
--- Updated ---
case CMP is
    when 1 =>LED<= "1111001";
    when 2 =>LED<= "0100100";
    when 3 =>LED<= "0110000";
    when 4 =>LED<= "0011001";
    when 5 =>LED<= "0010010";
    when 6 =>LED<= "0000010";
    when 7 =>LED<= "1111000";
    when 8 =>LED<= "0000000";
    when 9 =>LED<= "0010000";
    when 0 =>LED<= "0000001";
    when others =>
end case;
Hello Klaus,
Thank you very much for your answer. You are right according to my errors.
There was a problem with the "case when" syntax.
