Synplify get hostid problem under RH Linux 8.0
ch_wen
Junior Member level 3
When running Synplify / Pro 7.x in my RH linux 8.0 workstation, the license dialog shows it read the lastest byte of Ethernet ID as the HOSTID, such as "e4", "82", but even if I use that number as a hostid in license file, it always give out an "invaild host" message. Does anybody know how to solve this problem?
I think it is not a correct work to write your answer right here, so PM me, may be I can help you.
facing the same problem can u also mail the answer the ne
