I want to run power analysis in synopsys primetime, and I have generated the netlist and the sdc file of my design as well as the vcd file from modelsim. But when I run the PrimeTime, there’s such error:
Error: Can not find any event in the event file. (PWR-248)
In the generated power report, the power is 0.
So what does this mean?
Actually I am not using .spef file to annotate parisitics and .sdf file is not read by new versions in primetime. Can I do power simulation without .spef file for parasitics in primetime?
If you are on a pre-placement step of the ASIC flow then you don't need the .sdf for PrimeTime. The .sdf is used to produce the .vcd file which contains info for the switching activity of the design given a set of test vectors. If written correctly that should be enough to generate a power report using PrimeTime.
