Greetings colleagues,
I am currently working on the Synopsys Low Power Flow Workshop (Lab 3 Synthesis). The library files used in this design are :
1) saed90nm_hvt_rdsr.db
2) saed90nm_lvt_rdsr.db
3) saed90nm_max_hth_hvt_rdsr.db
4) saed90nm_max_hth_lvt_rdsr.db
I have specified the operating condition for the design as WORST in the library saed90nm_max_hvt_rdsr
While executing compile_ultra, the operation does not proceed due to the following warnings:
No default operating condition is defined for library saed90nm_hvt_rdsr
No default operating condition is defined for library saed90nm_lvt_rdsr
No default operating condition is defined for library saed90nm_hth_hvt_rdsr
No default operating condition is defined for library saed90nm_hth_lvt_rdsr
I know that in order to synthesize a multi-voltage design, a default operating condition has to be specified for each of the libraries. How do i go about doing this ?
