rijudg
Newbie level 3
I am synthesizing some designs using my own custom cells. I am trying to see how different parameters like clock and load affect the synthesis and / or timing.
The issue is, no matter what I do to the set_load parameter, my synthesis never complains or never reports a SLACK violation. However, changing the clock period does change the SLACK as expected. Any ideas how to check if set_load is doing anything?
Here is the script I am executing:
# set TOP to the name of the module to be synthesized
set TOP "mealy"
set edifout_netlist_only "false"
# paths for libraries used in synthesis
set search_path [concat {. /opt/CDS/cadence2005/ic5141/tools.lnx86/dfII/etc/dci/synlibs} $search_path]
#set target_library [list "/home/kaushikd/Digital_Synthesis/dno/NangateOpenCellLibrary_PDKv1_3_v2010_12/Front_End/Liberty/NLDM/NangateOpenCellLibrary.db"]
#set link_library [list "/home/kaushikd/Digital_Synthesis/dno/NangateOpenCellLibrary_PDKv1_3_v2010_12/Front_End/Liberty/NLDM/NangateOpenCellLibrary.db"]
set target_library [list "/home/kaushikd/Digital_Synthesis/timing/ibm32lib.db"]
set link_library [list "/home/kaushikd/Digital_Synthesis/timing/ibm32lib.db"]
set CLKPERIOD "1"
#set target_library [list "/home/kaushikd/Digital_Synthesis/synth/reduced2_typical.db"]
#set link_library [list "/home/kaushikd/Digital_Synthesis/synth/reduced2_typical.db"]
# Read in the design
define_design_lib control -path ./CONTROL
analyze -work control -f vhdl ../vhdl/$TOP.vhdl
elaborate -lib control $TOP
# Define clock (period in ns)
create_clock clk -name clk -period $CLKPERIOD
set_propagated_clock clk
# Define output load (in pF)
set_load 10000000000000000 [all_outputs]
# Set the optimization constraints
set_max_area 0
set_max_dynamic_power 0
# Map and optimize the design
current_design $TOP
uniquify
set_flatten true -effort medium -minimize multiple_output -phase true
# Run synthesis
compile -ungroup_all -map_effort high -incremental_mapping
# Run lint on the design
check_design
# Create some reports
redirect [format "%s%s" $TOP ".area"] { report_area }
redirect [format "%s%s" $TOP ".power"] { report_power }
redirect [format "%s%s" $TOP ".timing"] { report_timing -max_paths 25 }
redirect [format "%s%s" $TOP ".clock"] { report_clock }
# write output
write -hierarchy -format vhdl -output [format "%s%s" $TOP ".vhdl"]
write -hierarchy -format ddc -output [format "%s%s" $TOP ".ddc"]
# write a design constraints file for use by Encounter
write_sdc [format "%s%s" $TOP ".sdc"]
set TOP "mealy"
set CLKPERIOD "1"
set_max_area 0
current_design $TOP
uniquify
# Run synthesis
check_design
# write output
