Did you forget to put text labels / ports "VSS" and "VDD" on your layout, on the corresponding nets metal shapes?
It's hard to tell from the snapshot you provided, what's wrong.
What flow are you using?
Calibre LVS / DRC then StarRC for extraction?
Can you check if you have nets VDD and VSS on .SUBCKT line in DSPF file?
(DSPF file is a standard output from extraction tools - a post-layout netlist, in text format, you can see easily and directly all the nets, ports, etc. in the extracted netlist, unlike in extracted view).
extraction tools have some expectations regarding VDD/VSS pins and how they should be named. it is possible the tool is expecting vdd! and you called VDD, or whatever other combination of. check your extraction scripts.
In lab3 (parasitic extraction), Fig. 6 - select "Format" to be "SPF" (or "DSPF"), if it's available - and you will get a DSPF file format - a simple text file format for post-layout netlist.
It's content is (almost) identical to OA format, but OA is binary, and DSPF file text, so you can see all the information easily.
*|DSPF 1.3
*|DESIGN inverter
*|DATE "Tue Oct 22 23:50:15 2019"
*|VENDOR "Synopsys"
*|PROGRAM "StarRC"
*|VERSION "L-2016.06-SP3"
*|DIVIDER |
*|DELIMITER :
**FORMAT SPF
** COMMENTS
** OPERATING_TEMPERATURE 25
** GLOBAL_TEMPERATURE 25
** TCAD_GRD_FILE /hdd1/Ibtesam/Custom_designer/SAED_PDK90nm/starrcxt/saed90nm.nxtgrd
** TCAD_TIME_STAMP Mon Mar 21 07:56:03 2016
** TCADGRD_VERSION 80
.SUBCKT inverter VDD VIN VOUT VSS
*|GROUND_NET VSS
*LAYER_MAP.................................."
Good, the .SUBCKT statement looks good.
You can also check *|NET section for nets VDD and VSS, to make sure these nets are extracted correctly - and you can then assume that the extraction went though correctly.
If so - the problem is not with the extraction, but with how you use extracted netlist further up the circuit hierarchy.
Check your test bench, hierarchy editor, etc. - whatever you use to define your test bench, where you instantiate the extracted netlist.
*|NET VIN 0.000819726PF
*|I (MM0:GATE MM0 GATE I 5e-17 -3.79 4.29) // $llx=-3.79 $lly=4.29 $urx=-3.79 $ury=4.29 $lvl=30
*|I (MM1:GATE MM1 GATE I 2.5e-17 -3.79 2.16) // $llx=-3.79 $lly=2.16 $urx=-3.79 $ury=2.16 $lvl=29
*|P (VIN B 0 -4.105 3.085) // $llx=-4.11 $lly=3.015 $urx=-4.1 $ury=3.155 $lvl=82
*|S (VIN:1 -3.7975 3.085) // $llx=-3.855 $lly=3.015 $urx=-3.74 $ury=3.155 $lvl=44
*|S (VIN:2 -4.34 3.085) // $llx=-4.34 $lly=3.015 $urx=-4.34 $ury=3.155 $lvl=44
Cg3_1 MM0:GATE VSS 4.51691e-16
Cg3_2 VIN:2 VSS 7.84798e-17
R3_1 MM0:GATE VIN:1 8 $a=0.0169 $lvl=67
R3_2 MM0:GATE MM1:GATE 0.001 $l=2.13 $w=10 $lvl=29
R3_3 VIN:1 VIN 0.197679 $l=0.3075 $w=0.14 $lvl=44
R3_4 VIN:2 VIN 0.151072 $l=0.235 $w=0.14 $lvl=44
*|NET VOUT 0.000979819PF
*|I (MM0:DRN MM0 DRN B 0 -3.74 4.29) // $llx=-3.74 $lly=4.29 $urx=-3.74 $ury=4.29 $lvl=5
*|I (MM1:DRN MM1 DRN B 0 -3.74 2.16) // $llx=-3.74 $lly=2.16 $urx=-3.74 $ury=2.16 $lvl=4
*|P (VOUT B 0 -3.52 2.85) // $llx=-3.59 $lly=2.845 $urx=-3.45 $ury=2.855 $lvl=82
*|S (VOUT:1 -3.52 4.4775) // $llx=-3.59 $lly=4.42 $urx=-3.45 $ury=4.535 $lvl=44
*|S (VOUT:2 -3.52 4.16) // $llx=-3.59 $lly=4.16 $urx=-3.45 $ury=4.16 $lvl=44
*|S (VOUT:3 -3.52 2.1025) // $llx=-3.59 $lly=2.045 $urx=-3.45 $ury=2.16 $lvl=44
C4_3 MM0:DRN MM0:GATE 1.44505e-16
C4_4 MM0:DRN VIN:2 1.34042e-19
Cg4_5 MM0:DRN VSS 2.73739e-16
C4_6 MM1:DRN MM0:GATE 7.74372e-17
C4_7 MM1:DRN VIN:2 1.03982e-19
Cg4_8 MM1:DRN VSS 1.68193e-16
C4_9 VOUT:3 MM0:GATE 2.21731e-17
C4_10 VOUT:3 VIN:2 4.52021e-17
Cg4_11 VOUT:3 VSS 2.48332e-16
R4_5 MM0:DRN VOUT:1 10 $a=0.0169 $lvl=66
R4_6 MM0:DRN VOUT:2 10 $a=0.0169 $lvl=66
R4_7 VOUT:1 VOUT:2 0.204107 $l=0.3175 $w=0.14 $lvl=44
R4_8 VOUT:2 VOUT 0.842144 $l=1.31 $w=0.14 $lvl=44
R4_9 MM1:DRN VOUT:3 10 $a=0.0169 $lvl=66
R4_10 VOUT:3 VOUT 0.480536 $l=0.7475 $w=0.14 $lvl=44
*|NET ln_N7 0PF
*|NET ln_N8 0PF
* Instance Section
XMM0 MM0:DRN MM0:GATE VDD VDD p12 l=0.1u nf=1 w=0.5u
XMM1 MM1:DRN MM1:GATE VSS VSS n12 l=0.1u nf=1 w=0.25u
.ENDS"
