Hi Guys,
How can I make Ciranova Pycell Studio work with Synopsys Custom Layout?
I have a linux machine with Synopsys Custom Layout and Ciranova Pycell Studio installed.
1) Synopsys Custom Layout work properly.
- I can open and edit layout in Synopsys Custom Layout.
2) Pyros in the Ciranova Pycell Studio also works properly.
- I can open the sample pcells and change its parameters.
My problem is, how can I make the two work together? I have a PyCell Package library which I would like to use on my Custom Designer Layout. But when I Instantiate the PyCell in my TEST library, It only displays a small dot, the pycell doesn't shows up on my Layout.
Then I notice this error on my CustomDesigner console:
Cannot find IPcell 'cnDloPcell': Pcell evaluator 'cnDloPcell' not found: Shared Library Not Found: Error loading library 'libcnDloPcell.so'. /home/synopsys/Cdesigner/F-2011.09-1/suse64/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /home/PYCELL/plat_linux_gcc44x_64/lib/libcnDloPcell.so).
Can anyone help me with my problem? Any help will be greatly appreciated.
Thank you!
