stephkre4
Newbie level 2
Hello,
I am trying to use some ball valves I bought, however some of the ball valves will not always turn when supplying the voltage. Other times it will. Does this mean it is bad? Or is there some circuitry I can add to fix the motor to always start.
When the motor doesn’t turn, it is just shaking.
The part I have is a TDY50.
In my research I found that it is a synchronous motor and that they have two windings and they have to becomes synchronized. So I was hoping I could add some circuitry to correct the starting issue.
Thank you,
Stephen
Thank you,
Stephen
