At initial PIN 32 will be in high state.when the switch is turned ON an sequence will execute in the controller and the LED connected with the switch have to glow which indicate the sequence is turned ON.
But when the SWITCH is TURNED ON the LED not glowing and their is no action in the controller also.If I checked the controller without the LED part means working fine.
R16 (470 ohms) looks as though it could be a pull-up resistor. Is that correct?
Try a higher ohm value because 470 ohms wastes 10mA and moreover may alter voltage levels thus disrupting the circuit's operation.
I'm not sure but I think you haven't connected the three terminals or the switch - one to pull-up resistor, one to GND and one to the control signal. It looks like terminal 1 is not connected.
I wrote this before. I was thinking it was some kind of three-terminal switch controlled by some other logic. Now I realize it's some kind of push-button.
First of all, consider whether the switch is a momentary push-button or not. If it is a momentary push button, then your code has to look at it momentarily too, if not the controller will see a "high" after the switch has been released, meanwhile you are expecting it to see a "low".
Another thing is that you have used 0 and 1 to represent the switch state in your code. It is easy to mistake 0 for 1 and vise versa in this representation.
Maybe we need to take a cold-eye look at your code.
To fully analyse the circuit you provided, I need to know what is there connected with those three control terminals.
If it's not possible to provide those details then all I can suggest is that
1. voltage level is not enough at the switching terminal
OR
2. Due to some logic error, LED is becoming reversed biased.
Please check these once to be sure.
Thank You.
