Switch from analloglib Cadence
antlhem
Member level 1
Hi, I am using the switch from analoglib in Cadence. But, seems to behave wrongly, any suggestions on how to configure the switch to output the signal only when the control is activated?
Attached you can see my circuit and the results
Only when the control signal is activated the output should show if the switch behaves correctly
Switch configuration
Everything behave correctly. 1T is not infinity, so as long as you are looking on unterminated swith you see its input no matter switch is on or off. Add at least load cap there.
