Supply currrent of PIC10F20X when at <4MHz frequency
T
treez
Hello,
We need a low power micro powered from 5V.
PIC10F20X all consume 1mA at 5V. Thats too much for us.
Do microchip do a 6pin micro which can have its INTOSC adjusted to say 100kHz so it can consume less current? Or are they all stuck at 4MHz?
There used to be a list of all PICs , stating their capabilities, but its been removed from the web
All we need is for the micro to turn a NPN on for 20ms every 5mins.
PIC10F20X
https://ww1.microchip.com/downloads/en/DeviceDoc/40001239F.pdf
You can achieve µA supply current by waking up the processor periodically from WDT.
Reactions: treez
    T
Look at the 10F320 series. Typical IDD is 28uA while running at 31KHz and you can internally switch to higher speed/current under program control. They are available in 6-pin 'SOT' packages.
Brian.
Reactions: treez
    T
