Mar 3, 2012 #1 B BartlebyScrivener Member level 5 Joined Feb 8, 2012 Messages 90 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 2,081 Hi. In my testbench I have an array Code: real batchTotal [10]; which I am trying to total up into the real number. Code: real total by using the following code Code: total <= batchTotal.sum(); which compiles fine, however when I try and simulate I get the following error. Code: # ** Fatal: (vsim-8144) C:/altera/11.0/networkTest.sv(336): Reduction methods require packed elem. values. # Time: 0 ps Iteration: 1 Process: /networkTest/#ALWAYS#330 File: C:/altera/11.0/networkTest.sv # Fatal error in Module networkTest at C:/altera/11.0/networkTest.sv line 336 # # HDL call sequence: # Stopped at C:/altera/11.0/networkTest.sv 336 Module networkTest # Any ideas? I am confused because the code worked when I was using int value type, but as I am using a division to get the values I want to use real type. When I changed from int to real, it stopped working. Thanks in advance!
