[SOLVED] suitable cross reference for ATMLU742
cgchas
Member level 3
I recently ordered 24C64 8kx8 Serial CMOS EEPROM and what I got was ATMLU742.
The packaging is the same, but I cannot seem to find verification that ATMLU742 is a suitable crossreference for 24C64.
Can anybody point me in the right direction?
Charles
alexan_e
Administrator
Greece
I searched through google and there were a couple of Chinese sites with IC lists,
ATMLU742 is shown to be a AT26DF161 but I have no idea where is this format ATMLUxxxxx specified, I haven't seen it before so I can't verify if this info is correct.
Alex
Reactions: cgchas
    cgchas
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
Not the same device!
24C64 is an 8k x 8 device
26DF161 is a 16Mb x 8 device.
Both made by Atmel.
Brian.
Reactions: cgchas
    cgchas
cgchas
Member level 3
Alex
I have since found a few lists that seem to confirm this as well.
It appears they sent a completely wrong part in the same DIP-8 package.
The AT26DF161 uses 2.7V - 3.6V Supply
The AT24C64 uses 2.7V - 5.5V Supply
I am glad I checked before plugging it in.
Best Regards,
Charles
---------- Post added at 10:54 ---------- Previous post was at 10:46 ----------
Both made by Atmel.
Brian.
Yes, one is a 64K storage device and the latter is 2048K storage!
Not to mention that 26DF161 is Flash and 24C64 is an EEPROM.
Thank you for the response.
Charles
alexan_e
Administrator
Greece
Another difference is that the eeprom 24C64 uses I2C while 26DF161 uses SPI.
In any case if you want to use it then you can make a simple 3v3<->5v level translator to interface the 3v3 device with the 5v mcu
5V-3.3V bidirectional level converter « rocketnumbernine
Alex
---------- Post added at 19:29 ---------- Previous post was at 19:29 ----------
Alex
cgchas
Member level 3
