julian403
Full Member level 5
Hello All.
Looking if there is a equipmente connected to a switch, in this case I was looking a nomadix I foud this table.
As the Switch is a 2-layer all that it's connected to it is in the same network so Why there is equipment with difference ip?
Ok, looking the network diagram there is a mikrotik router connected to that switch you can see that it's the 10.141.152.2 (you can see that the MAC vendor is routerboard) and there is a modem there, too. which make as a gateway.
The Switch match all ip that "pass through" his ports? or just the ip that are connected to it? in this last case why there is two difference networks
Thanks and regards.
Thanks and regards.
