Strange Question : Why these values ?
superluminal
Member level 4
Member level 4
Inside a quantum well
This is a simple question but I can not answer it.
Why usually resistors & caps are shipped in specific values like 47K,82K,91K & 47uF,2200uF ..etc , why these values & not , for example, 10 20 30 ..etc ?
buzkiller
Member level 4
Member level 4
These values are supposed to give the best possible choose when cascaded together to form other values.
regards,
Buzkiller.
Epegic
Member level 5
Member level 5
Values are defined to covered 10% torlerance range.
dkace
Full Member level 6
Full Member level 6
Greece
Logical question for someone trying to design simple circuits for a begining. I think buzkiller gave an adequate answer on the point. If you check several schematics you'll find out that cirquit to ground connection, feedback in op amps etc, is accomplished with some of these values. If you also see the list of electronic elements in a lab, yo' ll see that also the fixed values of 10,20,etc are also there.
So a statistic from the use in real cirquits , will show you that this "odd" values are appearing more than often in the cirquits. What is more, cascade between a resistor of 40 Ω, 5Ω and 2Ω, to make a 47Ω one, can cause capicity or noise problems. So it is easier to make one 47Ω from the beginning! :idea:
Aoxomox
Member level 5
Member level 5
hi dkace,
please correct me if I am wrong or maybe I only know half of the storry.
Well when being able to produce resistors with a tolerance of 10% then the absolute tolerance increases with increased absolute value.
Example:
R=10 Ohms deltaR = +- 1 Ohms
R=100 Ohms deltaR = +- 10 Ohms ( >1 Ohms)
so when producing a product portfolio how do you best cascade these values when you want to produce as few different components and still want to cover all values possible??
linear case with steppsize
Values : 10 20 30 40 50 60 70 80 90
Tolerances: 9-11 18-22 27-33 36-44 45-55 54-66 63-76 72-88 81-99
As you can easily see the tolerances in the beginning of the series don't overlapp and for increasing values (like 90) the tolerance edge meets almost the center value of the neighbour.
with a logarithmic stepsize you have:
Values : 10 22 33 47 68 82
Tolerances: 9-11 19.8-24.2 29.7-36.3 42.3-51.7 61.2-74.8 73.8-94.6
As you can see there are less single values needed and the tolerance edges almost meet for higher vaues within one decade.
Fewer different components are cheeper to produce, distribute, store.......
You are right in saying that fewer components in series have good affect to noise performance but for increasing accuracy in producing components I think it's not neccessary to combine them. 1% tolerated resistors are standard today and thoses series (E96) have much more single components than the E24 (10%) have.
hope it helps.
aOxOmOx
dkace
Full Member level 6
Full Member level 6
Greece
Hi aoxomox,
you seem quite informed on the matter. I was speaking out of experiance-limited to say the truth-. I had the same question as superluminal, in my first steps in electronics. I think your answer is quite sophisticated, so I have to accept it!
:wink:
superluminal
Member level 4
Member level 4
When I was doing my first circuits long ago,I was asking this question & I was answered like what buzkiller & dkace said & I accepted this ( & still).Now it was my turn for a beginner to ask me this question & I answered him but he asked for manufacturing reasons for these values & thanks Aoxomox ; now I can answer him.
And thanks to answer me why metal film R's (1% tol.) are in many values than carbon R's (10 %).
jzaghal
Full Member level 2
Full Member level 2
Hi all,
Search for E12 and E24 with google and you will find the answer to your question on resistor tolerances.
:D :D :D
Best wishes.
j_o_n_i
Junior Member level 3
Between Apenines and Balcans
Hey everybody, remember there are also the variable resistors to help. They're not only used to do adjustments ( eg. adjust the volume ), but also to help in achieving difficult resistor values. You could use one of them (usually in series with another resistor) instead of putting several resistors in series and/or parallel. It would help to resolve the problems dkace was talking about. :arrow:
Methanol
Junior Member level 1
Hi everybody I agree with Aoxomox but let me add one more think. The usual resistors and capacitors values (10,12,15,18,....) come from the beginning of the radio,by that time resistors and capacitors were usually manufacturated with a 20% tolerance (fourth band gold=5% ,silver=10% ,without fourth band=20%).
So if you first value is 10 the next one should be 10+20% (if you want overlap) so the next should be 12. You can build and small table.
10
10x1.2=12
12x1.2=14.4~15
15x1.2=18
18x1.2=21.6~22
22x1.2=26.4~27
27x1.2=32.4~33
etc.
Regards.
Methanol
Kit-the-great
Full Member level 3
Full Member level 3
Russia
'Strange' nominals of res/caps
Nominals of components choosing by the manufactures on this reason:
Minimum number of nominals to obtain all values (by serial/parallel combinations).
Just it easiest way to manufacturer.
Just a business, not personal !
With response,
Kit-the-great
RegUser_2
Full Member level 2
Full Member level 2
Oh well, the interesting question here is how precise the paralel/serial combination of a resistors is usefull. So far the only place such precision is needed is in the feedback loop of an active filter (to define the filter behaviour), yet if someone look on the capacitance tollerances (at best about 2%), the need of better matching for the resistors is pretty much questionable. In general the gain matching (as well as the frequency responce of a filter) are mapable via correct calibration procedures during the process of measurement, hence the need of high precision components (and in this sense the standard set of values) aren't much critical. Naturally in case of a digital design, the needeed set of resistors (and their matching) is much relaxed. In case of power supply applications, the desired tollerances won't need be much better than say 5%. So yes, why do we need even the 1% set values? :)
In my humble opinion the thermal properties (the TKC/TKR matching) are a lot more important than having extended set of values though ;)
Aoxomox
Member level 5
Member level 5
Hi RegUser_2
you are right that for high resolution applications low tolerated components are not enough. there you need a calibration procedure where (in analogue case trimpots/trim caps, in digital case a frequency response and/or offset, gain etc.) correction values are defined to compensate the behaviour of the circuit.
This is usefull for low volume devices like high perfomance mesurement equipment with high prices.
But in all other cases where high volume products are assembled it will be much to expensive to adjust every single circuit if one can avoid this procedure just by using low tolerated components.
sometimes the expense for a very few capacitors with 2% tolerance will even be cheaper than manual or automatical adjustment of the circuit.
aOxOmOx
