Alexwonglik
Newbie level 5
- Joined
- Feb 15, 2015
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 59
Hi I tried to use verilog to develop a stop watch on a fpga board seven segment display. It doesn't count correctly (See the video: https://www.youtube.com/watch?v=uHqJeKxjPrA) I guess the problem is from the counter.v and top.v? However, I can't figure what's wrong with the code. Hopefully, someone can give some hints.
// 4 digit enable module
module enable_sr(
input clk,
output enable_D1,
output enable_D2,
output enable_D3,
output enable_D4
reg [3:0] pattern = 4'b0111;
assign enable_D1 = pattern[3];
assign enable_D2 = pattern[2];
assign enable_D3 = pattern[1];
assign enable_D4 = pattern[0];
always @(posedge clk) begin
pattern <= {pattern[0],pattern[3:1]};
end
endmodule
// counter module
module counter(
input button0,
input button1,
input clk_point1hz,
output reg reg_d0,
output reg reg_d1,
output reg reg_d2,
output reg reg_d3
reg stop;
wire reset;
assign reset = button1;
always @(posedge button0)
stop <= ~stop;
always @(posedge clk_point1hz)
if (stop == 1 && reset ==1) begin
reg_d0 <= 0;
reg_d1 <= 0;
reg_d2 <= 0;
reg_d3 <= 0;
end else if (stop == 1) begin
reg_d0 <= reg_d0;
reg_d1 <= reg_d1;
reg_d2 <= reg_d2;
reg_d3 <= reg_d3;
end else if (stop != 1) //if no stop
begin
if(reg_d0 == 9) //xxx9
begin //if_0
reg_d0 <= 0;
if (reg_d1 == 9) //xx99
begin // if_1
reg_d1 <= 0;
if (reg_d2 == 9) //x999
begin //if_2
reg_d2 <= 0;
if(reg_d3 == 9) //9999
reg_d3 <= 0;
else
reg_d3 <= reg_d3 + 1;
end // end if-2
else //else_2
reg_d2 <= reg_d2 + 1;
end
else //else_1
reg_d1 <= reg_d1 + 1;
end
else //else_0
reg_d0 <= reg_d0 + 1;
end
endmodule
// seven segment display module
module ssd(
input [3:0] hex,
output reg [6:0] segment,
output dp
always @ (*)
case (hex) // use little endian, so need to reverse the ucf segment as it uses big endian
0: segment = 7'b0000001;
1: segment = 7'b1001111;
2: segment = 7'b0010010;
3: segment = 7'b0000110;
4: segment = 7'b1001100;
5: segment = 7'b0100100;
6: segment = 7'b0100010;
7: segment = 7'b0001101;
8: segment = 7'b0000000;
9: segment = 7'b0000100;
default: segment = 7'b0000001;
endcase
assign dp = 4'b1111;
endmodule
// top module
module top(
input clk,
input button_n,
input reset_n,
output [6:0] segment,
output enable_D1,//right most digit
output enable_D2,
output enable_D3,
output enable_D4,//left most digit
output dp,
output reg_d0,
output reg_d1,
output reg_d2,
output reg_d3
wire clk_point1hz;
wire refreshClk;
reg [3:0] hex;
clock_gen Uclk_gen(
.clk(clk),
.refreshClk(refreshClk),
.clk_point1hz(clk_point1hz)
enable_sr Uenable(
.clk(refreshClk),
.enable_D1(enable_D1),
.enable_D2(enable_D2),
.enable_D3(enable_D3),
.enable_D4(enable_D4)
counter Ucounter(
.button0(button_n),
.button1(reset_n),
.clk_point1hz(clk_point1hz),
.reg_d0(reg_d0),
.reg_d1(reg_d1),
.reg_d2(reg_d2),
.reg_d3(reg_d3)
ssd Ussd(
.hex(hex),
.segment(segment),
.dp(dp)
always @ (*)
begin
if (enable_D1 == 1 && enable_D2 == 1 && enable_D3 == 1 && enable_D4 == 0)
assign hex = reg_d0;
else if (enable_D1 == 1 && enable_D2 == 1 && enable_D3 == 0 && enable_D4== 1)
assign hex = reg_d1;
else if(enable_D1 == 1 && enable_D2 == 0 && enable_D3 == 1 && enable_D4 == 1)
assign hex = reg_d2;
else if(enable_D1 == 0 && enable_D2 == 0 && enable_D3 == 0 && enable_D4 == 1)
assign hex = reg_d3;
end
endmodule
