vikasvij1982
Newbie level 5
I have generated the top level verilog and also the scan patterns using Tetramax. But since the verilog_single_file command to write patterns has been depricated, I could only get STIL format. My question is that is there a way in which i can directly import the output patterns generated by Tetramax and use them in Modelsim. I am able to compile the top level verilog generated by tetramax but not able to use the scan patterns. If not then is there any other simulator wherein i can do this. If possible can you either give me the list of commands to do that or direct me to a link..
Regards
Vikas
Regards
Vikas
