Stereo to speaker/RCA conversion !
uhrams
Newbie level 3
India
Hi ! PC stereo connector outputs [three of them for 5.1 channel] need conversion for 6 speaker inputs. Each of the three stereo outputs from the PC should be converted to 4 wires for two speakers. How can I get four wires from two ?
Also, the amplifier has RCA inputs marked left and right speakers and I need to make a stereo to RCA cable to connect PC stereo output to the amplifier input. I hope the stereo to RCA conversion is a simple one to one connection.
Thanks in advance.
I think the outputs from your pc are line level and are designed to drive amplifiers, not speakers.
Amplifiers drive speakers.
If you connect six speakers to three amplifiers then the amplifiers might be overloaded which will cause them to shut down, or blow up.
