Raghu
Junior Member level 1
stepper motor dynamo
I am using a 2.75Nm rated ( Pull out torque ) bipolar stepper motor. This has a winding resistance of 2.3 Ohms per phase; Rated current of 2 Amps / Phase. and Inductance of 14mH/Phase.
I am using the L297 + L298 combination driver as a bipolar chopper for driving the motor in full step mode. The supply is at 12V / 10 A rating.
I am unable to achieve the quoted torque if I increase the clock frequency beyond 500Hz and the motor just stalls. ( the motor data sheet shows the torque drooping only after 1000 Steps/ sec) . The load is just frictional and not inertial.
I currently use a clock source that can be varied between 100 to 1500 Hz but not ramping it . I am told that if I apply the clock with a ramp from 0 Hz to 1000 Hz in a time of say 0.5 Sec, then the stepper will support 2.75 NM at 1000 Hz.
Kinldy advise if my information on ramping the frequency is correct.
( If so I can then use the 555 clock source as a VCO and ramp the frequency )
Thanks.
Raghunathan
Thanks.
Raghunathan
