ericmar
Full Member level 5
step-up switching regulator
May I know if it is harmful for the input voltage supplied to a step-up switching regulator to be higher than the step-up voltage at the output?
In fact, I found a sentence in the datasheet of a step-up regulator (MAX668) stating that "regulation cannot be maintained if V_IN exceeds V_OUT". What does this actually mean?
If it is and there is no way to lower down the input voltage, then should I use a zener diode to clamp down the input voltage? Would this waste the power on the supplying power?
Please advise. Thanks.
Regards,
Eric
Regards,
Eric
