std_logic type question
alexz
Full Member level 5
Full Member level 5
UK
Is the std_logic type used for sinthesys as well as for simulation?
Or I should use the 'bit' type for the real device programming?
std_logic works in both
What about other values then '1' and '0' ?
other logic states are also there as well say for example 'z' is high impedencce used mostly for bus probing,then a unknown state means the voltage level is in between high and low logic so undetermined then then the case with weak 1 and 0 more prone to noise than the strong one.hence bobth std_logic as wll as bit type are used
