hi leoren_tm
i think the clock devide part should be writen in this way:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY main IS
PORT(
input_old : in std_logic_vector( 1 downto 0);
clk, pb : in std_logic;
output : OUT STD_LOGIC_VECTOR(10 downto 0));
END main;
ARCHITECTURE struct OF main IS
TYPE STATE_TYPE IS (s0, s1, s2, s3);
signal state: STATE_TYPE;
signal clk_delayd : std_logic ;
signal input_new : std_logic_vector(1 downto 0);
signal cnt : std_logic_vector(11 downto 0);
BEGIN
PROCESS (clk)
BEGIN
IF (clk'EVENT AND clk = '1') THEN
cnt <= cnt + 1;
IF (cnt = 2048) THEN
clk_delayd <= '1' ;
ELSIF (cnt =0) THEN
clk_delayd <= '0';
else
null;
END IF;
END IF;
END PROCESS;
in this way you can get the aera decreased and timing slack increased.
Added after 7 minutes:
a even beter way :
LIBRARY ieee;
ENTITY main IS
PORT(
END main;
BEGIN
PROCESS (clk)
BEGIN
cnt <= cnt + 1;
END IF;
end process;
clk_delayd <= cnt(11);
