i designed a state machine,when proeceeing the design ,the RTL of state machine is correct.
BUT,when i generate its symbol,and conenct it in the top entity,the RTL state machine is not same as the sub_module, and generate the warning
Warning (10272): Verilog HDL Case Statement warning at controlflat.v(112): case item expression covers a value already covered by a previous case item
All state need to be unique (not sure I understand the question). How you encode the state does not matter as the sythesis tool will re-incoded them to as is sees fit anyway.
Try to use names to encode your state (easier to read - I don't know how to do this with Verilog).
