in sta ,to do setup and hold check, we need to select wire load mode, but there usualy have worst wire load mode and best wire load mode.how to select this two mode to do setup and hold check?
u must use best operating conditions for hold checks and worst operating conditions for setup check. wireload selection is same for both setup and hold check. it is the libraries and operating conditions which decides whether u r selecting worst or best conditions.
setup time = clock cycle - max data delay
hold time = max clock delay(skew) - min data delay
With worst case condition, setup time can get most critical value,
With best case condition, hold time can get most critical value in mostly environment.
hi dolby,
In fact, wire load mode is based on statistic, so it has low accuracy for timing analysis excecially for hold check. So i think it is better to do hold check with RC information instead of WLM
