First set the path as false path between the clock domains.
Then
1. If there is no data going through between these clocks then fine no problem. U can carry on with the STA.
2. If not then u need to have FIFO design with sufficient depth, so that there r no data lost. Which is normally written in the verilog code itself by the coding team.
