SSD0323 OLED Controller interface to dsPIC (help)
ArjunSC
Member level 1
ssd0323
Hi everybody,
Has anyone used the "OSRAM's 27" OLED with SSD0323 inbuilt controller, if so please help me with the programming. I want to interface the OLED to the dsPIC microcontroller.
oled controller user interface
Hi
There are nice app note on OSRAM site show how to connect OLED dispaly to micro controller to 8080 system
You will need to emulate a 8080 bus on Dspic - easy just use I/O port
I f you are writing in C language i can send you some code
All the Best
Bobi
oled controller
HI bobcat,
thanks for the reply, please mail me the source code to michaelarjun@gmail.com, Please describe about the performance of the OLED.
*The OLED power dissipation depends on the number of pixels on.
*Also the OSRAM guys have not given an option for internal +12V, although the controller has it.
[/youtube]
oled interfacing
Hi
You will need an external boost regulator 3.3V->12V to activate the dispaly
Code you ask in annex - not tested by me - not sure if it's work at all
All the best
Bobi
dspic oled
hi bobcat1:
I use OLED to display something,but it can not work. Can you send me an Email of SSD0323 OLED source code . thanks a lot. My Email : chenjun@3g.com.cn
