[SOLVED] SRAM butterfly curve
warlocklw
Newbie level 5
Newbie level 5
SRAM butterfly curve - HSPICE / CosmosScope
Greetings. I wish to ask for method to create butterfly curve. It's V(q) vs V(qb). When I use DC analysis, I can sweep voltage q and observe voltage at qb, but the voltage q will be a linear increase straight line. If I were to observe the transition of q and qb, i will have to use transient analysis. How do I create a v(q) vs v(qb) butterfly curve? Thanks in advanced.
_________________________________________________________________________________________________________________________________________________
SRAM4
.option abstol=1e-6 reltol=1e-6 post ingold
.hdl "bsimcmg.va"
.include "modelcard.nmos"
.include "modelcard.pmos"
.global vdd!
.param vdd=1
Vvdd! vdd! gnd dc=vdd
* --- Source ---
VWL vWL gnd dc=0
Vqq q gnd
* --- Inverter Subcircuit ---
.subckt inverter vin vout vddi vss
Xp1 vout vin vddi vddi pmos1 TFIN=15n L=30n NFIN=10
Xn1 vout vin vss vss nmos1 TFIN=40n L=30n NFIN=10
.ends
* --- 1 unit SRAM ---
Xinv_top qb q vdd! 0 inverter
Xinv_bot q qb vdd! 0 inverter
* --- Access Transistor ---
Xn5 qb vWL BLB gnd nmos1 TFIN=20n L=30n NFIN=10
Xn6 q vWL BL gnd nmos1 TFIN=20n L=30n NFIN=10
* --- Analysis ---
.dc Vqq 0 1 0.01
.print dc v(q) v(qb)
.end
which version of Spice you follow?
Because I am with Hspice 2008 version, will this FinFET configuration work for it?
Re: SRAM butterfly curve - HSPICE / CosmosScope
SRAM4
.hdl "bsimcmg.va"
.global vdd!
.param vdd=1
* --- Source ---
VWL vWL gnd dc=0
Vqq q gnd
.ends
* --- Analysis ---
.dc Vqq 0 1 0.01
.end
Solution, check journal below:
https://www.hindawi.com/journals/jnm/2014/820763/
Hello
can please help me,draw butterfly curve,iam doing project on SRAM
i want write netlist sram in write mode please help me
thanks
