[SOLVED] square wave detector
A
ats2
Hello,
I want to create an enable signal for LT4356 hot swap controller using 12V-500Hz square wave. I designed the circuit below, the input is 12V 500Hz square wave and output is SC. However, I am looking for an alternative safer and/or simpler circuit.
Alternatively, using an frequency to voltage converter like LM2907 a good choice?
Can you help me?
Thanks in advance.
LM2907 is a very old device and may be hard to find. Do you really need to measure the frequency? If you do, consider using a small MCU which could easily measure frequency and amplitude in one device.
You can simplify the circuit by removing D1 and shorting across C1, the voltage may be a little lower but it will still measure it and the voltage will still be proportional to the input amplitude.
Brian.
    A
"Square wave detector"
What detail of the square wave are you interested in?
* frequency
* amplitude
are the most obvious ones.
Are you expecting a YES/NO output of your detector?
Then you should specify at which condition it should safely show a "YES" and at which condition it should show a "NO".
Klaus
    A
Interested in frequency.
Yes, I need a high low output.
I want to keep the enable pin away from voltage noises. Any noise at square wave net must not effect the enable pin of lt4356 pin.
Maybe like this:
Input signal --> narrow 500Hz bandpass filter --> rectifier --> low pass filter --> schmitt trigger --> enable signal
It reacts on 500Hz sinewave.
But a square wave includes sinewaves, thus it should work.
Mind: "zero noise" is impossible.
Klaus
    A
Thank you very much Klaus. What kind of low pass filter do you recommend?
Thanks in advance.
depends on reaction time.
You may use a second order, but is has lower suppression of unwanted signals and is slow.
A second order (or higher order) may be faster and does more effectively suppress unwanted signals.
Klaus
    A
