alangs
Member level 3
see below code of square root of a number.....here the output is coming after finishing of 15 clock....i need this code to give output of square of a number at less number of colck (2 or 3 clocks)...can any one do this and send me the code....
module sqrt
parameter DATA_WIDTH = 8,
ANSWER_WIDTH= 8,
TRIAL_WIDTH = 4
clk,
data,
start,
answer,
done
input clk;
input start;
input wire[DATA_WIDTH-1:0] data;
output reg [ANSWER_WIDTH-1:0] answer;
output done;
//reg [DATA_WIDTH:0] answer;
reg busy;
reg [1:0] bit;
wire [TRIAL_WIDTH-1:0] trial;
assign trial = answer | (1 << bit);
always @ (posedge clk)
begin
if (busy)
begin
if (bit == 0)
busy <= 0;
else
bit <= bit - 1;
if (trial*trial <= data)
answer <= trial;
end
else if (start)
begin
busy <= 1;
answer <= 0;
bit <= 3;
end
end
assign done = ~busy;
endmodule
module sqrt
ANSWER_WIDTH= 8,
TRIAL_WIDTH = 4
clk,
data,
start,
answer,
done
input clk;
input start;
output done;
reg busy;
reg [1:0] bit;
begin
if (busy)
begin
if (bit == 0)
busy <= 0;
else
bit <= bit - 1;
answer <= trial;
end
else if (start)
begin
busy <= 1;
answer <= 0;
bit <= 3;
end
end
endmodule
