The general gist is you vary the frequency of the clock randomly around its nominal frequency. the energy gets spread out over a wider spectrum. Otherwise you end up with large energy spikes at the base frequency. This is just away to distribute the energy. There are mulitple ways to implement, typically you have some a random oscillator that either changes the charge/discharge current of the oscillator. You can switch in more/less capacitance etc. There are many ways to implement this.
Have a ramp generator, convert it into pulse , divide this pulse to get the modulation frequency required (divide by 8 or whatever) , use this divided clock to charge discharge a capacitor around a DC value and use this voltage to modulate the current source which is generating the ramp / triangular wave.This will be a loop.This will modulate the ramp @ the freq. of the divided clock.
Cool!!! Thanks bro.... Are you pretty sure this will be a stable system? . I tried simulating it at Matlab or Labview based on some of the mathematical facts on your suggestion but couldn't get it running. I need specific data and more info! Would you mind?
