neazoi
Advanced Member level 6
I am building this one http://www.techlib.com/files/RFDesign3.pdf
I would like to make the PSU for it. http://tangentsoft.net/elec/bitmaps/vgrounds/vfb-opa.png It should have better performance with a AD817 opamp. It should work fine up to 50mA min if using an AD817, so I think it can feed all three opamps nicely, yet being simple.
My problem is with the grounding scheme.
The circuit will be made inside a small enclosure similar to this http://neazoi.com/refosc/DSC07698.JPG
Where should I have to connect the virtual ground and where the real ground (V-) on the circuit?
I have two guesses.
First guess:
1. Connect the virtual ground at the opamps ground connections (that is the 100R ground and the decoupling caps and the circulator/isolator switch)
2. Connect the real RF ground to the ports SMA connectors and the chassis.
3. Connect the mains real PSU ground to the chassis (this is the negative voltage as seen by the opamps)
Second guess:
1. Connect the virtual ground at the opamps ground connections (thats the decoupling caps grounds only, nothing else)
2. All the other grounds in the circuit go to the V-
I am a little bit confused about the grounds, What do you think I should do?
I have two guesses.
First guess:
Second guess:
