SPI between two different microcontrollers problem
foxbrain
Full Member level 2
Damas
Hi
i'm working on spi communication between atmega168(master) and atmega16(slave)
the problem is that the slave receives what the master send but the master can't read what the slave sends.here r the codes:
Atmega 16:
#include <avr/io.h>
#include <util/delay.h>
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#define RF_PORT	PORTB				// SPI Port
#define RF_DDR	DDRB
#define RF_PIN	PINB
#define SDI		5					// MOSI Pinnummer
#define SCK		7					// SCK Pinnummer
#define CS		4					// CS Pinnummer
#define SDO		6					// MISO Pinnummer
//unsigned int d=0;
// Initialize SPI Slave Device
void del (unsigned int dela)
	for (int i=0;i<dela;i++)
		asm("NOP");
void spi_init_slave (void)
	RF_DDR&=~((1<<SDO));
	RF_DDR&=~((1<<SCK));
	RF_DDR&=~((1<<CS));
	RF_DDR|=(1<<SDI);
    SPCR = (1<<SPE)|(1<<CPOL)|(1<<CPHA)|(1<<DORD);   //Enable SPI
unsigned char spi_tranceiver (unsigned char data)
	asm("NOP");
    SPDR = data;
	while(!(SPSR & (1<<SPIF)));
	asm("NOP");
    return(SPDR);                      //Return received data
int main(void)
	unsigned char a=6;
	unsigned char b;
	asm("NOP");asm("NOP");asm("NOP");asm("NOP");asm("NOP");asm("NOP");
	DDRD=0xFF;
	spi_init_slave();
    while(1)
		SETBIT(PORTD,0);
		_delay_ms(500);
		CLEARBIT(PORTD,0);
		_delay_ms(500);
        b=spi_tranceiver(a);
		if (b==5)
			PORTD=0xFF;
			_delay_ms(500);
			PORTD=0x00;_delay_ms(500);
Atmega 168:
#include <avr/io.h>
#ifndef cbi
#define cbi(sfr, bit)     (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit)     (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define RF_DDR	DDRB
#define RF_PIN	PINB
#define SDI		3					// MOSI Pinnummer
#define SCK		5					// SCK Pinnummer
#define CS		2					// CS Pinnummer
#define SDO		4					// MISO Pinnummer
void spi_init_master (void)
  	//RF_PORT=(1<<CS);
	RF_DDR|=(1<<SDI)|(1<<SCK)|(1<<CS);
	SPCR=(1<<SPE)|(1<<MSTR)|(1<<CPOL)|(1<<CPHA)|(1<<DORD);
//	SPSR |= (1<<SPI2X);
	cbi(RF_PORT, CS);
    SPDR = data;                       //Load data into the buffer
	sbi(RF_PORT, CS);
int main(void)
	unsigned char a=5;
	unsigned char b;
		CLKPR=(1<<CLKPCE);
		CLKPR=(0<<CLKPS0);
		CLKPR=(0<<CLKPS1);
		CLKPR=(1<<CLKPS2);
		CLKPR=(0<<CLKPS3);
	DDRD=0xFF;
	DDRC=0xFF;
	spi_init_master();
    while(1)
		SETBIT(PORTC,0);
		_delay_ms(500);
		CLEARBIT(PORTC,0);
		_delay_ms(500);
		if (b==6)
			PORTD=0xFF;
			_delay_ms(500);
Please Help!!!!
If possible...can you please show the circuit of the system?
Atmega168..............atmega16
MOSI----------->MISO
MISO----------->MOSI
SS-------------->SS
SCK------------->SCK
and the vcc and gnd connected
each microcontroller is connected to crystal 3.5MHZ with 2 capacitors to the ground
I think it might be a mismatch of baud rate(s)...The baud rate for the operation of slave sending data to master,and the baud rate when the master sends data to slave...you have kept them the same,right?
Can you please explain the code for both master and slave units..The functions part,after defining the pins and header files?
well the first part is the initialization which is for the master to set the pins mosi and ss and sck as output and miso as input , in the slave the opposite and also selecting the slave and master
the commands : CLKPR=(1<<CLKPCE);
to make at168 works at the same clock speed of at16
the function spi_tranceiver for transmitting and receiving data since i put the data in the SPDR register then wait until transmission is done then it returns what i had received.
i made a blinking led on port D,0 to make sure the micro controller don't fall into a finite loop
when i get what i had sent all pins in port d are ones.
how can i make the synchronization?
