foxbrain
Full Member level 2
Hi
i'm working on spi communication between atmega168(master) and atmega16(slave)
the problem is that the slave receives what the master send but the master can't read what the slave sends.here r the codes:
Atmega 16:
Atmega 168:
Please Help!!!!
Thanks
Atmega 16:
#include <avr/io.h>
#include <util/delay.h>
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#define RF_PORT PORTB // SPI Port
#define RF_DDR DDRB
#define RF_PIN PINB
#define SDI 5 // MOSI Pinnummer
#define SCK 7 // SCK Pinnummer
#define CS 4 // CS Pinnummer
#define SDO 6 // MISO Pinnummer
//unsigned int d=0;
// Initialize SPI Slave Device
void del (unsigned int dela)
for (int i=0;i<dela;i++)
asm("NOP");
void spi_init_slave (void)
RF_DDR&=~((1<<SDO));
RF_DDR&=~((1<<SCK));
RF_DDR&=~((1<<CS));
RF_DDR|=(1<<SDI);
SPCR = (1<<SPE)|(1<<CPOL)|(1<<CPHA)|(1<<DORD); //Enable SPI
unsigned char spi_tranceiver (unsigned char data)
asm("NOP");
SPDR = data;
while(!(SPSR & (1<<SPIF)));
asm("NOP");
return(SPDR); //Return received data
int main(void)
unsigned char a=6;
unsigned char b;
asm("NOP");asm("NOP");asm("NOP");asm("NOP");asm("NOP");asm("NOP");
DDRD=0xFF;
spi_init_slave();
while(1)
SETBIT(PORTD,0);
_delay_ms(500);
CLEARBIT(PORTD,0);
_delay_ms(500);
b=spi_tranceiver(a);
if (b==5)
PORTD=0xFF;
_delay_ms(500);
PORTD=0x00;_delay_ms(500);
#include <avr/io.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define RF_DDR DDRB
#define RF_PIN PINB
#define SDI 3 // MOSI Pinnummer
#define SCK 5 // SCK Pinnummer
#define CS 2 // CS Pinnummer
#define SDO 4 // MISO Pinnummer
void spi_init_master (void)
//RF_PORT=(1<<CS);
RF_DDR|=(1<<SDI)|(1<<SCK)|(1<<CS);
SPCR=(1<<SPE)|(1<<MSTR)|(1<<CPOL)|(1<<CPHA)|(1<<DORD);
// SPSR |= (1<<SPI2X);
cbi(RF_PORT, CS);
SPDR = data; //Load data into the buffer
sbi(RF_PORT, CS);
int main(void)
unsigned char a=5;
unsigned char b;
CLKPR=(1<<CLKPCE);
CLKPR=(0<<CLKPS0);
CLKPR=(0<<CLKPS1);
CLKPR=(1<<CLKPS2);
CLKPR=(0<<CLKPS3);
DDRD=0xFF;
DDRC=0xFF;
spi_init_master();
while(1)
SETBIT(PORTC,0);
_delay_ms(500);
CLEARBIT(PORTC,0);
_delay_ms(500);
if (b==6)
PORTD=0xFF;
_delay_ms(500);
Thanks
