I have successfully run a monte carlo (transient) and extracted the vth for each run (using the "finalOptime") option.
Anyone know how to set this up same vth extraction in spectre command line? Adding the finalOptime option in the command line run only outputs a single monte carlo run. I should in theory be able to copy all settings from the ADE run and get the correct results, the problem is cleanly copying all those results over.
