sweetsalt
Hi all!
I am asked to perform a spectral analysis using Fourier techniques of the following 64 points.which are obtained by sampling a continous signal at 4000hz.
-2.2084441e-001
1.0841281e-001
-2.2566847e-002
-7.1269979e-001
-7.7570468e-001
1.5490627e+000
1.9458210e-001
-8.9878564e-001
2.5642118e-001
1.2323886e+000
-2.5090429e-001
-6.4754173e-001
-2.8157727e-001
1.8196999e+000
-3.4228194e-001
-1.0446433e+000
5.8907411e-001
4.8584173e-001
7.0878880e-001
2.1880127e-001
1.2519184e+000
2.9170207e-001
1.2549903e+000
1.2138000e+000
-3.1823385e-001
-4.6785664e-002
-2.3964629e-001
-1.7661788e+000
-1.4964292e+000
-3.6095019e-001
-1.1122538e+000
2.1902688e-002
6.1575414e-001
1.3917852e+000
-3.2921212e-001
7.7902325e-001
6.3796904e-001
-1.2476316e+000
9.7494022e-001
-7.5831465e-001
-1.0848348e+000
6.0460012e-001
-1.4021865e+000
1.3785847e+000
-6.5360020e-001
-4.9165649e-001
9.8713534e-001
-1.0617638e+000
-1.0888472e+000
6.9453009e-001
6.1975115e-001
8.5906752e-001
9.9296393e-002
1.8264694e-001
-6.5977471e-001
-1.0669556e+000
1.5649163e-001
3.4083024e-001
8.9142667e-001
6.5523161e-001
1.1048760e-001
-8.1966173e-001
-2.1416913e-001
-1.6509091e+000
Now the problem is when i do, stem(abs(fft(x)) , what i should get must be symetric around its center, because it a real signal.
real signal has frequency only from 0 to pi ( comments needed?? )
so values from 0 to pi must repeat from pi to 2pi,
But in my case fft is not symetric, the first value is causing problem, like i have 64 point fft, 31 values around 33rd values are symetric, but the value at 1 is like no where in the signal again, y is thats so???
if any one can do the given signal's spectral analysis for me, it would be great help.
i am doing
yf=fft(x,64);
y = yf(1:33); % just look at first half
m = abs
; % m = magnitude of sinusoids
p = unwrap(angle
); % p = phase of sinusoids, unwrap() % copes with 360 degree jumps
w=0
i/32
i;
subplot(2,1,1), stem(w/pi,m); % plot magnitudes
ylabel('Abs. Magnitude'), grid on;
xlabel('\omega/\pi');
subplot(2,1,2), stem(w/pi,p*180/pi); % plot phase in degrees
ylabel('Phase [Degrees]'), grid on;
plz help me urgent, deadline is 2morow.
Thanks in advance
-2.2084441e-001
1.0841281e-001
-2.2566847e-002
-7.1269979e-001
-7.7570468e-001
1.5490627e+000
1.9458210e-001
-8.9878564e-001
2.5642118e-001
1.2323886e+000
-2.5090429e-001
-6.4754173e-001
-2.8157727e-001
1.8196999e+000
-3.4228194e-001
-1.0446433e+000
5.8907411e-001
4.8584173e-001
7.0878880e-001
2.1880127e-001
1.2519184e+000
2.9170207e-001
1.2549903e+000
1.2138000e+000
-3.1823385e-001
-4.6785664e-002
-2.3964629e-001
-1.7661788e+000
-1.4964292e+000
-3.6095019e-001
-1.1122538e+000
2.1902688e-002
6.1575414e-001
1.3917852e+000
-3.2921212e-001
7.7902325e-001
6.3796904e-001
-1.2476316e+000
9.7494022e-001
-7.5831465e-001
-1.0848348e+000
6.0460012e-001
-1.4021865e+000
1.3785847e+000
-6.5360020e-001
-4.9165649e-001
9.8713534e-001
-1.0617638e+000
-1.0888472e+000
6.9453009e-001
6.1975115e-001
8.5906752e-001
9.9296393e-002
1.8264694e-001
-6.5977471e-001
-1.0669556e+000
1.5649163e-001
3.4083024e-001
8.9142667e-001
6.5523161e-001
1.1048760e-001
-8.1966173e-001
-2.1416913e-001
-1.6509091e+000
i am doing
yf=fft(x,64);
m = abs
p = unwrap(angle
w=0
Thanks in advance
