Specifying Tap cells distance
kpsr
Member level 1
Member level 1
Hi Folks,
We are specifying some x distance (50u) between tap cells.
How they are specifying this distances. On what bases they they are specifying a particular value.
Please replay this as soon as possible
Thanks in advance
kpsr
DRC rule of nwell connection, or the latch-up rule chapter inside the Design Rule Manual from the founder.
for TSMC0.18, 60um is the maximum, then each 55um is correct.
Reactions: kpsr
    kpsr
hi rca
can u give a example, which drc name can be found this distance?
Regards
phoney
