Specific Verilog questions...
XoioX
Newbie level 3
Newbie level 3
UK
Hi everyone,
I am going through a piece of code (in Verilog and converting it to VHDL) and although I can simulate it to check what it does, I'd like to make sure I understand the principle behind this line
InputComEncoded = InputCom[3] ? 2'b00 : 2'b10;
Where InputComEncoded and InputCom are defined as:
input [3:0] InputCom;
reg [1:0] InputComEncoded
Am I right to think that InputCom[3] only refers to 1 bit (MSB) of InputCom?
In which case, what is really going on when I compare a 2 bit word with a single bit signal?
When using this conditional statement: A = B ? m : n
Am I right to think that if A = B then A = m else A = n ?
Thanks for your help
(yes I am very new with Verilog! ;-) )
No, it means A = m if B is true, A = n if B is false.
This construct also exists in the programming language C,
with the same meaning.
Why don't you check with a Verilog text book or compiler manual? It's not so effective to guess about the meaning of language contructs.
So you mean, that A is both receiving the result and used in the compare? Sounds strange, isn't it?
The Verilog c?x:y construct is identical to C language, the c term is tested for equality to zero. It can be replaced by a conditional VHDL assignment
InputComEncoded <= "00" if InputCom(3)= 1 else "10";
LaTeX Commands Quick-Menu:
