Hi all,
When I tried special routing, I got a few warnings shown below.
**WARN: (SOCSR-1253): Net VDD does not have standard cells to be routed. Please check net list.
**WARN: (SOCSR-1254): Net VDD does not have block pins to be routed. Please check net list.
**WARN: (SOCSR-1255): Net VDD does not have pad pins to create pad ring. Please check net list or port class. (must NOT be CORE class and must not be AREAIO subclass).
**WARN: (SOCSR-1256): Net VDD does not have CORE class pad pins to be routed.
Net VDD does not have AREAIO class pad pins to be routed.
**WARN: (SOCSR-1253): Net VSS does not have standard cells to be routed. Please check net list.
**WARN: (SOCSR-1254): Net VSS does not have block pins to be routed. Please check net list.
**WARN: (SOCSR-1255): Net VSS does not have pad pins to create pad ring. Please check net list or port class. (must NOT be CORE class and must not be AREAIO subclass).
**WARN: (SOCSR-1256): Net VSS does not have CORE class pad pins to be routed.
Net VSS does not have AREAIO class pad pins to be routed.
**WARN: (SOCSR-468): No core cells defined in COMPONENTS section
and/or No core cells defined in SPECIALNETS VDD
CPU time for FollowPin 0 seconds
and/or No core cells defined in SPECIALNETS VSS
I do not know what's wrong with my netlist, but I found there were no VDD and VSS pin for every standard cell in netlist. Do these warnings mean that I need to add VDD and VSS pin for each standard cell?
Thanks in advanced
