fuzzzy
Full Member level 3
replacement speaker mylar 50 ohm resistor
HI,
I'm repairing an electronic device, it has a loudspeaker to change.
It seems a Mylar speaker. 50mm diameter. there is write on it: 0.2W 50F 50 OHM
I found on catalogues similar speaker with same power but i can only find max 22 OHM.
Can I use modify this speaker to fit my device?? can i use 22 OHM in your opinion?
Where can i Find 50 OHM speaker??
Thanks
HI,
Thanks
